Author Topic: Looking for o-ring KIT for 68 250SL Fuel Pump  (Read 4166 times)
vaqua55
« on: September 23, 2009, 21:25:56 »
I recently started to rebuilt my Fuel Pump and am in need of finding the o-rings that go in it (I believe total of 5 pcs), what material are they to handle the Fuel, what sizes are they and where can I get them as a package or individually.
This is for the SHORT FUEL PUMP.
Thanks for your input.
George Des
Re: Looking for o-ring KIT for 68 250SL Fuel Pump
« Reply #1 on: September 23, 2009, 21:47:09 »
A proper rebuild will require the o-rings, metal seals and brushes. Send me an e-mail if you need a kit for this.
George Des
RickM
« Reply #2 on: September 29, 2009, 14:35:45 »
Buna-n is the most common material used and is resistant to the effects of gasoline. However, as formulas evolve with new additive packages, a proactive individual would consider Viton O-rings.
Further info: http://www.biofuels.coop/archive/viton.pdf
One source is www.mcmaster.com for the individual pieces. If you go this route please let us know the sizes.
George: Does your kit utilize Viton O-rings...or is it an option?
« Last Edit: September 29, 2009, 14:40:09 by RickM »
George Des
« Reply #3 on: September 29, 2009, 22:05:46 »
I've been using nitrile-same as buna-n---considering that this is what was used in the originals and they last a long time, Viton for this purpose in my opinion is somewhat of an overkill
RickM
« Reply #4 on: September 30, 2009, 14:12:15 »
IMHO, the minimal increase in cost is worth it. Did you read the DuPont article I linked to? Fuel is not the same as when our cars were built.
