Author Topic: Seal around the neck of the gas tank  (Read 3487 times)
shane
« on: September 26, 2009, 18:11:26 »
Well,10 months later,I finally got my car back from the panel shop.I am extremely satisfied with the spray job,but bitterly dissapointed with the way they have reassembled the car.One thing I need help with,is the seal around the neck of the gas tank.They have misplaced it.Can someone post a picture of this seal,it will be a great help.Thanks
Shane
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Witt
Re: Seal around the neck of the gas tank
« Reply #2 on: September 28, 2009, 02:46:29 »
......very recently I completed my resoration and replaced said seal. It came fro the "Benz-Doctor" in Toronto,( a member of this site)  not that expensive if I remember correctly.
I installed it by using WD40 to make it a bit slippery and installed it in a "screw-on" fashion: remove the gas cap, slip the gasget over the neck and twist it in a clockwise rotation, making sure the groove in the rubber will engage with the body sheet metal. Stop rotating when it is in the desired position! "Groovy"........worked for me.
CHEERS !
WITT !  ;)
shane
« Reply #3 on: October 07, 2009, 19:08:06 »
Thanks Guys,after producing a photo of the seal intact and fitted,the panel shop admitted fault,and agreed to replace,thanks for the ebay pick Garry,at least I can check if they have supplied the right part.Witt,will b sure to give them the fitting instruction.Cheers Shane
