Author Topic: Drain holes in soft top well  (Read 3725 times)
Larry & Norma
« on: September 27, 2009, 10:07:36 »
Hi, one of the drain holes in the soft top well seems to be blocked about 1 inch from the top. Where does the hole lead to, i.e where does the water exit the car?
How do i unblock it, is there an easy way other than brute force. I understand that there are rubber tubes on these drains and don't want to tear them. Are they accessable?
Larry
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Re: Drain holes in soft top well
« Reply #1 on: September 27, 2009, 10:22:55 »
Hello, Larry,
It drains into the chamber in front of the rear wheel arch, and then out from the gap under the second trim peice
I would use a lot of water and a little persuasion.
« Last Edit: September 27, 2009, 10:25:50 by naj »
Larry & Norma
« Reply #2 on: September 27, 2009, 16:48:20 »
Thanks Naj, that really explains everthing!!
2023 Ioniq6
2005 C230
