Author Topic: Distributor Point Cleaning or POSSIBLE UPGRADE  (Read 2795 times)
vaqua55
« on: September 28, 2009, 17:16:45 »
We are in process of cleaning the distributor points from my 68 250SL that has original mechanical points that has a tremendeous amount of build up, thus I was wondering if it will be a better idea to try to upgrage the DISTRIBUTOR system with electronic spark control (such as HALL Sensor) instead of mechanical points? What would you recommend and where can I buy this upgraded distributor system that will be a FIT for my 68 250SL?
Thanks as always for all your insight:)
RickM
Re: Distributor Point Cleaning or POSSIBLE UPGRADE
« Reply #1 on: September 28, 2009, 18:24:30 »
Here's a tech article on the subject: http://www.sl113.org/wiki/Electrical/ElectronicIgnitions
MSD ignitions can be used as well. A search on the subject will serve you well...
