ive had bad clunks in my rear end ever since i got the car. replaced the trunk mount,got better a bit. re-did all exhaust mounts/hangars, again a little better. but it still clonks every once in a while under these circumstances. i checked main driveshaft u/j, no play
stick in "2" postion, partial throttle, put in "3" about 30 mph. sounds nasty.
partial throttle about 25 mph. breifly press and release accelerator, clonks
randomly when turning and accelerating quickly
i recently had the car up on stands and i rotated the left side axle, no slop. but when i turn the right axle there was significant play from either side when turing the wheel, about 1 inch in movement before the opposite wheel started turing.
i was wondering if this means the u/j slider assembly is bad, because i am about to put in new thrust arm bushings and pivot bushings, but if the u/j is the issue i want to do it all in one shot
thanks,
alex
