Thank you all once again.
My first valve adjustment (first valve adj on an MB, that is) is complete and successful.
I broke my 10 mm allen head socket when trying to loosen my first head bolt (brand S&K). That was scary
It broke at less than 120 ft-lbs. So, it must have had a defect of some kind.
After buying a new 10 mm, all loosened with less than 120 ft-lbs.
All valve adjusted without needing to remove the rocker arm and use a 6-point socket.
Three of my intakes were "very" loose (greater than 0.15 mm clearance).
I can't believe how the car feels, revs, sounds, pulls, and shifts
BETTER.
I wouldn't have done it without the website. Thanks to all !
