Author Topic: Preparing for flexdisk removal  (Read 4718 times)
Eminent
« on: October 06, 2009, 21:43:56 »
Hello.
Soon i'm gonna replace the flexdisk from the Benz.
In the Haynes manual is written that i need two large spanners to release the sleeve-nut (page 130).
Somebody can tell me what the size of the spanners should be?
Thanks in advance.
Rini.
Re: Preparing for flexdisk removal
« Reply #1 on: October 07, 2009, 00:17:07 »
41mm and 46mm
Eminent
« Reply #2 on: October 07, 2009, 07:23:33 »
Thanks. They're pretty large indeed. See if i can find someone who have these.
Thanks again.
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: October 07, 2009, 13:35:24 »
You can get them online from Northern Tool.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Eminent
« Reply #4 on: October 07, 2009, 13:52:46 »
Thanks. But i think it's cheaper to buy them in the Netherlands.
DavidBrough
« Reply #5 on: October 08, 2009, 11:45:01 »
You might find it easier to use a large adjustable as these generally have a shorter shaft than 40+mm spanners and a better angle on the head. If you have a pit or a lift it will make no difference but you do have to raise the car quite high to get the long spanners in. I have both but always use the adjustable as it's just too difficult raising the car to the height required to use the spanners. Also, you should only need one as the shaft can be locked in gear or park.
Eminent
« Reply #6 on: October 08, 2009, 12:32:20 »
Thanks for the tips David.
I will keep it in mind.
