Jeff and Naj,
Good news and bad
The GOOD news is that both your instructions were spot on, especially the diagram.
The BAD news - I found that both the flappers are broken. Both have one of their moulded pins broken so they don't hinge properly and one has the actuating lever that the cable attaches to snapped off. PLUS, the attachment point for the actuating arm of the water valve is broken off on the left one.
So, I need two new flappers (Naj?) In some way I was a bit surprised they were made of bakelite, especially the left one which also operates the heater valve - destined to fail if the valve becomes a bit stiff - too much force.
One more question. The valve that switches air from up or down - clear lever top right is also stiff. I suspect that the after marked aircon unit is blocking that but I shall check it out. Does that lever operate a flapper style vent that directs air it to the screen and the footwell, or the screen and the airvents on the dash.
Cheers
George
PS Any leads on the two flappers would be greatly appreciated.
