Author Topic: How to tell year/month?  (Read 5161 times)
johnshenry
« on: October 21, 2009, 14:30:32 »
Hi group, newbie here in the process of purchasing a 113.
I am trying to find out the year/month of manufacture.  Does this plate have this information:
Or is it only from the VIN tag?
I have these numbers from the car I am looking at (this pic from the tech manual here), and I understand the last 5 digits are the body number, but is the VIN data on this tag such that I could find the month of manufacture in this table:
http://www.sl113.org/wiki/DataCard/USModelYear
Thanks.. many more Qs to come I'm sure
Re: How to tell year/month?
« Reply #1 on: October 21, 2009, 14:58:14 »
The table you found in the Tech Manual section shows the last 6 numbers of the VIN The 113 044 12 on the chassis tag tells us that the car is a 280 sl with left hand steering and automatic transmission, The VIN tag is on the left window post and the 6 digits that you are looking for start after the #12.
The color codes on the tag indicate the car is light blue metalic with a dark blue hard top and hubcaps.
johnshenry
« Reply #2 on: October 21, 2009, 15:27:39 »
Thanks Al.
So the VIN digits needed to tell manuf month are on the VIN tag/windshield post and not on the body tag shown in the pic, right?
« Reply #3 on: October 21, 2009, 23:17:33 »
Check the driver-side door threshold for a black & silver plate that's stamped with the manufacture date on the top right corner. That's one way. The other way is to cross-check the VIN against the chart in the database on this site that correlates serial numbers with production dates by month.
« Last Edit: October 22, 2009, 23:07:27 by Douglas »
louie2
« Reply #4 on: October 22, 2009, 03:02:31 »
The body number will also allow you to determine if hood and top go with car. The body number is stamped on underside of hood and on top below rear window.
johnshenry
« Reply #5 on: October 23, 2009, 02:39:05 »
I presume you mean the hardtop, right??
johnshenry
« Reply #6 on: October 27, 2009, 01:04:47 »
The engine number on this 280 I am looking is (if I am making the numbers out correctly): 130-983-12-004209
I am pretty sure it is original to the car.  Is there a list that correlates the engine number sequence number (004209) to a month/year?  The vin sequence number is 006598 and that seems to be a Nov '68 manufacture.
TIA
JH
Anfinn
« Reply #7 on: October 27, 2009, 13:43:04 »
The data-card from MB contains the Motor number and would confirm if it is original.
Looking at the difference in VIN and motor number to what is on the data-card of my car (October 1970 manufacture),
I have abt. 15000 higher VIN number, but only abt. 10000 higher engine no.
I don't know why there is a difference....
johnshenry
« Reply #8 on: October 28, 2009, 16:14:24 »
Can you mail MB and get new data cards for a card whose card has been lost?
Anfinn
« Reply #9 on: October 28, 2009, 17:03:54 »
You have to provide proof of ownership of the car to get a copy.
I am not sure if electronic copies are accepted. See the thread on Data card
I sent mine snail-mail.
« Last Edit: October 28, 2009, 17:08:06 by Anfinn »
« Reply #10 on: October 28, 2009, 17:51:52 »
Call Tom Hanson at the Classic Center and he'll get you a replacement.
See: http://www.sl113.org/forums/index.php?topic=10991.msg73997#msg73997
