Author Topic: Rubber intermediate mounting  (Read 5423 times)
Eminent
« on: October 22, 2009, 14:09:06 »
Hello.
In my search to where that deep vibrating sound come from i checked my flexdisk today.
There are a few tiny cracks in it so it should be replaced, no doubt.
But i don't think it's the cause of the sound.
The rubber donut (the intermediate rubber mounting) is kind of soft.
If i push the shaft up and down at that point it goes up and down for about 6mm.
My question, is it normal that i can push it up and down that much?
If so, i have to search further.
Anyhow, the donut will be replaced also when i do the flexdisk.
Thanks for your time and answers.
Rini.
« Last Edit: October 22, 2009, 16:21:07 by Eminent »
Eminent
Re: Rubber intermediate mounting
« Reply #1 on: October 23, 2009, 04:23:27 »
Hmmm....almost 70 views but no answer....gues this was a dumb question :-[
« Reply #2 on: October 23, 2009, 04:44:58 »
There are no dumb questions.
I would guess no one really has an answer (myself included). Please post your findings once you get through it.
Eminent
« Reply #3 on: October 23, 2009, 04:55:04 »
Thx, i will.
My thoughts are that the rubber mounting is there to eliminate vibration, but when it's to soft or worn it will allow the shaft to virbrate more.
I don't know how hard a new mountingrubber is.
I will post my experience here.
« Reply #4 on: October 23, 2009, 10:58:50 »
have you checked the universal joint on the rear of the drive shaft?
Eminent
« Reply #5 on: October 23, 2009, 18:23:15 »
No, unfortunately i did not.
Stupid from me to forget to check it.
I have made some pictures from it, but that shall not clear things up.
What i do see on the picture is that the oil seal from the dif needs to be replaced.
w113dude
« Reply #6 on: October 26, 2009, 21:32:59 »
I had a similar noise that was in my car, after looking every where, it turned out to be a defective rear tire! worth looking.
Shaun
Eminent
« Reply #7 on: October 27, 2009, 19:08:57 »
Thanks Shaun.
I have plans to re-balance the wheels soon.
Should something be wrong with the rims and/or tyres it will be noticed than.
Rini.
Witt
« Reply #8 on: October 27, 2009, 23:32:27 »
My vibrating, humming noise was solved after I replaced the top differential mount accessible through the luggage compartment.
Just my five cents worth....
CHEERS !
WITT !
« Reply #9 on: October 28, 2009, 02:51:35 »
Check those motor mounts also.  If they looked collapsed or the centers are punched through you will get metal to metal contact and all kinds of strange vibrations.
