Author Topic: body damage  (Read 5219 times)
xcashewx
body damage
« on: November 07, 2009, 17:18:11 »
got in a small collision yesterday when the brakes in my car deicded to wack out, hit the car infront of me at maybe 5 mph or less.
grille looks like a goner, headlight lens destroyed, and i cant get my hood open or off with the nose portion going under it.
i dont know weather or not to have a body shop try and repair it, or get a new nose panel and get that installed? any help is apreciated, i am clueless what to do with my car :(
w113dude
Re: body damage
« Reply #1 on: November 07, 2009, 17:37:03 »
A good body shop should be able to stretch in place and repair it, or in worst case they'll cut it and place it right. I have done similar work should not be a problem.
From what I can see you might be able to save the grill too!
Good Luck,
Dash808
  • USA, HI, Kaneohe
Re: body damage
« Reply #2 on: November 08, 2009, 07:44:40 »
Bummer.   I guess it could always be worse  :-\
Hopefully a little massaging by a good shop is all it will take.   What's going on with the brakes?
Chan Johnson
'67 250sl
Napoli Italian Euro
Bang Bang Booogie!
xcashewx
Re: body damage
« Reply #3 on: November 08, 2009, 08:49:00 »
The back brakes weren't grabbing..... Found out it was a leaky wheel cylinder and damaged brake shoes
Re: body damage
« Reply #4 on: November 08, 2009, 17:59:31 »
There's an Az resident that had a front end collision similar but with a bit greater damage than yours.  He took the car to Mark Pasarelli and it looked as good as new when completed.
Dash808
  • USA, HI, Kaneohe
Re: body damage
« Reply #5 on: November 08, 2009, 18:16:38 »
If you can't salvage your grill, I think you could find a buyer for your grill star  ;)
Chan Johnson
'67 250sl
Napoli Italian Euro
Bang Bang Booogie!
xcashewx
Re: body damage
« Reply #6 on: November 09, 2009, 03:11:54 »
is mark pasarelli a local here in AZ?
and dash, the star was broken clean out of the barrel
  • USA, WI, Mequon
Re: body damage
« Reply #7 on: November 09, 2009, 03:16:18 »
http://www.ranchomerced.com/
