Author Topic: Sway bar link torque spec  (Read 6264 times)
Blade
« on: November 14, 2009, 02:55:41 »
I would like someone to help me with the torque specs on the sway bar link bolts. I am replacing the bushings on the sway bar links and cannot find the correct torque settings.
Jim ???
JimVillers
  • USA, VA, Virginia Beach
Re: Sway bar link torque spec
« Reply #1 on: November 14, 2009, 16:55:44 »
Tight but not compressing the link bushing.  Be sure that the bushing is seated in the sway bar.
Jim Villers
« Reply #2 on: November 14, 2009, 19:01:51 »
In looking through the technical data book, what I could find for the suspension is "Hex. screws of torsion bar support on front axle" M8 (metric 8 mm) with a tightening torque of 2.5 mkp. The conversion is to multiply by 7.233.
Verification anyone?
« Reply #3 on: November 14, 2009, 19:38:57 »
The Workshop Manual section 32.6 shows that a specific distance 'a' needs to be maintained from the end of the bolt threads to the upper edge of the hexagon screw nut. Section 32.0 specifies 'a' to be 23 +/- 1 mm. This is the manual covering passenger vehicles starting August 1959 (the pages in question show "Modification Oct. 63")
What compounded this specification was that the original setup had a second thin nut serving as a lock on the main nut, but the replacement kit from MB came with a nylon lock-nut, instead of the pair. (a similar change occurred on all shock mounts). This would obviously affect the distance 'a'.
From my recollection, the replacement threaded link rod from the MB kit had been designed in such a way as to require the nut to be tightened in all the way until the end of the link rod threads, no matter how compressed the rubber gets. Measuring the length of the rod threads should give you a quick sanity check.
For reference, the specifications given in Section 32.0 are as follows:
Torsion Bar Fastening on Lower Control Arm
Models 190 c, 190 Dc, 220 b, 220 Sb, 220 SEb, 300 SE, 230 SL
Rubber Buffer Part No.111 323 00 44
Rubber Buffer Height28 mm
Rubber Hardness Shore50 +/- 5 degrees
Hexagon screw length200 mm
Spacer tube length68 mm
Distance 'a' from screw end to upper edge of hexagon screw nut        23 +/- 1 mm
Hope this helps.
« Last Edit: November 14, 2009, 19:41:54 by waqas »
Blade
« Reply #4 on: November 16, 2009, 19:46:33 »
Thanks for the help> I need to practice up on my metric conversion.
Jim
