Author Topic: problem while taking a cylinder head apart....  (Read 3783 times)
erickmarciano
  • Canada, Quebec, montreal
« on: November 22, 2009, 00:46:43 »
Hi all
have a spare head for my car I want to rebuilt. toke all apart and I damaged the thread in these 2 water fitings how and where should I fix theme?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
SteveK
Re: problem while taking a cylinder head apart....
« Reply #1 on: November 22, 2009, 02:44:58 »
I guess it all depends how bad.  If there not too messed up I would clean them out with a tap and then put the new fitting in with thread sealant.  If the threads are bad you will need to use a Helicoil.
« Reply #2 on: November 27, 2009, 00:55:05 »
I think you will find that the only real option is welding and re-machining.  Get ready though because my experience in this area is that they always have oddball  threads that are rarely used meaning your machinist will make you buy the tap to cut the threads at about $80 each.
Dave Gallon
  • USA, NC, Statesville
« Reply #3 on: December 23, 2009, 03:15:26 »
I completely ripped the threads out of one of those cooling water connections on a 220SEb head a few years back. (It was necessary to remove the fitting regardless of the consequences!) The local machine shop here in San Diego who specializes in Mercedes and other foreign products had no trouble repairing the hole by welding and rethreading it. So, do not get crazy with these fittings unless the head is off and you are willing to pay the price for thread repair. However, repair is possible if the shop is competent.
Dave Gallon
Gallon Restorations
113.044-12-001155
