Author Topic: Cylinder Head to Rebuild but slot near chamber  (Read 3110 times)
erickmarciano
  • Canada, Quebec, montreal
« on: November 25, 2009, 15:55:45 »
Hi all got a cylinder head I want to rebuilt by found this slot near the combustion chamber .is this normal?this is only on one chamber.
« Last Edit: November 26, 2009, 00:00:45 by 280SL71 »
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
If that slot goes into the coolant jacket it is a big problem and will have to be repaired.
Be aware that if the slot is from coolant corrosion damage there may be other  areas in the head which are corroded thin and weakened but have not yet broken through.
erickmarciano
it looks to perfect to be corosion . showed it to the machine shop and he thinks it is part of the head ...anyone have one to compare?
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Cylinder Head to Rebuild but slot near chamber
« Reply #3 on: November 26, 2009, 02:29:37 »
Hello Erick,
I have seen hundreds of heads.  None had a slot like this.  Possibly a broken ring or stray part was shoved up into the head by the piston. ? !
It should not cause any problems as long as it does not go into the coolant jacket.
