Please check out joining the
Emergency Contact List
for help during your travels!
Expansion Tank Hose Bracket? (Routes hose over alternator)
Topic: Expansion Tank Hose Bracket? (Routes hose over alternator) (Read 3866 times)
GermanCarScottsdale
November 26, 2009, 00:01:33 »
Hello All-
Did a quick search but didn't see anything on this (unless it's called something else!). I've seen photos of a bracket or guide that routes the hose from the expansion tank to the top of the radiator safely over the alternator. I can't remember where I saw the photos. Anyone know where I can find photos of this and/or where to get the part? Thanks for any help! Car is a '68 280SL.
Mike
Full Member
Platinum
USA, CA, Solana Beach
Re: Expansion Tank Hose Bracket? (Routes hose over alternator)
November 26, 2009, 02:59:59 »
Hi Mike,
it s all here, part number and where to get it - provided Dave Gallon still has one because it is a NLA part:
http://www.sl113.org/forums/index.php?topic=8580.msg56112
1966 230SL automatic 334G light blue (
sold
GermanCarScottsdale
Reply #2 on:
November 27, 2009, 21:55:01 »
Thanks for the link, I should have explained better, but I need the clip/bracket that seats on the alternator for a car with A/C (toward the front). Must look similar to that, but not quite the same. Needs to be an A/C car. Thanks-
Mike
Full Member
Platinum
Reply #3 on:
November 28, 2009, 05:33:44 »
The Frigiking parts list shows it as a 1/2 inch clamp (info provided by Dave Gallon).
But since A/C is an aftermarket item you can use whatever you like. As shown in the picture there are a number of variations on the clamp style and also the routing that were used.
Hope this helps.
Last Edit: November 28, 2009, 05:36:44 by 66andBlue
sold
