Author Topic: Carpet Removal from seat backs  (Read 4136 times)
tomaco1
« on: November 27, 2009, 19:06:41 »
Any hints on this? The carpet is really on there.
I tried heat, NG.
I'm thinking
1) get new ones
2) flip them over and face the old carpet into the seat
69280sl
  • USA, IL, Elk Grove
Re: Carpet Removal from seat backs
« Reply #1 on: November 28, 2009, 02:34:18 »
I faced the same problem. Used the old seatbacks as patterns to cut new ones out of masonite. Very easy. The vent trim and seat back retainer metal hide the cut edges.
Gus
Gus
paults1
  • USA, FL, The Villages
« Reply #2 on: November 28, 2009, 03:25:39 »
Try Laquer Thinner or Acetone. Soak corner, peel back a small area , apply thinner or Acetone, peel back, add moore, peel back, repeat.  This worked for me with Acetone.
Regards, Paul, '63 230SL
tomaco1
« Reply #3 on: November 28, 2009, 13:15:28 »
I'll give the acetone a try.
If that doesn't work i'll see how I do cutting new ones
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #4 on: November 30, 2009, 22:55:04 »
You might want to try the 3M product for removal of trim glue.  Comes in spray can and you can get it at Advance Auto, or Auto Zone.  It de-solves the glue
Robert Hyatt
Williamsburg, VA.
tomaco1
« Reply #5 on: December 01, 2009, 02:54:44 »
I'll try the 3M, acetone didn't even make it budge
