Become a
Full Member
Emergency Contact List
Electrical and Instruments
Cold Start System
Topic: Cold Start System (Read 6046 times)
healey100
Cold Start System
December 09, 2009, 16:15:30 »
Hi I have troubles trying to find out how to do the intalation, I have 2 realys, one thermo time relay and one thermo time swith, the car is a 230 SL 1965 engine number 127 981 10 011719, I need the wire diagram.
Full Member
Platinum
USA, OH, Blacklick
Re: Cold Start System
December 10, 2009, 14:17:08 »
I can help you with this. Do you have these parts on your car already? I will need to know what is on your car now. The 230SL had two versions. The early version can be converted to the later. I will need to know what nubers are on your two terminal "thermo time switch" ?
Reply #2 on:
December 12, 2009, 01:02:24 »
Here is the applicable section of the wiring diagram for the 230SL. No 21 is the relay for automatic starting aid. No 31 is the electromagnetic starter valve and the thermo time switch is no 32.
Cold Start System
