Author Topic: Headlight removal - 1977 280 SL  (Read 5038 times)
a1handy
« on: December 29, 2009, 15:46:53 »
I need to repair some rust around the headlight and trim but would like some advice or instructions on how to remove the headlight assembly. I need to do this to be able to repair the body close the trim and assembly. Is there any online source of information or illustrations. Any general instructions would be helpful
« Last Edit: December 29, 2009, 15:49:24 by a1handy »
Larry & Norma
Re: Headlight removal - 1977 280 SL
« Reply #1 on: December 29, 2009, 18:40:53 »
If you have a 1977 280SL then you are on the wrong site! This is for Pagoda type SL (1963-1971)
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #2 on: December 29, 2009, 20:29:33 »
Yes, yours is a W107.
There is a thin panel below the headlamp assy with a hole at the corner. You have to remove the screw in that hole and a couple more on the same panel that are under the hood.
Once off, the headlamp/amber lens can be removed as an assembly after removing the screws holding the headlamp frame to the body.
Also, for more help:
http://sl107.com/eve/forums/a/frm/f/2346035941
a1handy
« Reply #3 on: December 30, 2009, 10:21:36 »
Thanks and I have not gone to the correct site. Sorry
RickM
« Reply #4 on: January 05, 2010, 22:43:43 »
A1,
Here are pics showing how to remove a 107 Euro headlight assembly. The wiring harness/connector simply plugs into the rear of the light.
If, however, you are converting from US to Euro headlights you will need to rewire to accommodate the differences.
Hope this helps.
http://www.peachparts.com/shopforum/showpost.php?p=690373&postcount=1
« Last Edit: January 06, 2010, 14:42:03 by RickM »
