Author Topic: Washer Pump - Priming  (Read 3465 times)
« on: January 11, 2010, 21:24:22 »
Installed a vintage windshield washer pump on a 280SL...with new tubing.
Pump is not spraying. VOM meter shows power going to the pump.
Maybe the pump needs to be primed?
If yes, how do you prime the pump? If "mouth-power" is needed, OK to do it with blue fluid in the reservoir or use plain water? or what?
Richard M, NYC
gnj588d
Re: Washer Pump - Priming
« Reply #1 on: January 11, 2010, 21:35:14 »
I used mouth power to prime the pump{clean water}worked fine,if its the same pump as a 65 230
Ulf
« Reply #2 on: January 18, 2010, 11:25:38 »
I had the same problem, took mine apart which was surprisingly easy, sprayed every component with WD40, put it back together and it has worked perfectly ever since...
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
