Author Topic: Spring fasteners  (Read 2771 times)
bogeyman
  • USA, NE, Omaha
Spring fasteners
« on: January 15, 2010, 23:03:45 »
I just got a radio delete plate that has the spring fasteners for the 280SL script. I need to repaint it to my color.
Does anyone have a way to remove these spring clips?  They are similar to the clips that hold the script to the trunk lid.
I hate to just grab them with a pair of pliers and hope for the best...
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
merrill
Re: Spring fasteners
« Reply #1 on: January 16, 2010, 02:13:07 »
If it is anything like the one on my 230 I'd get a small "L" shaped tool like a pick and then push
up on the inside of where the spring goes over the stud.
as you push up on the inside you open up the metal just enough to release the tension so you can
slide the spring off.
If you grab it with a pliers you may distort the clip.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
