Author Topic: sloppy stick shifter  (Read 13181 times)
Michael D.....
« on: January 17, 2010, 02:04:22 »
I'm newer to the world of 113.  I'm methodically going through and restoring the vehicle.  In my pursuit to get the vehicle in the best mechanical condition I can, I noticed that my stick shift has a lot of lateral play once it is shifted into position (once in gear I can move the sick 3-4 inches back and forth).  It glides in and out of gears well but it is not a firm track that the stick moves in like modern car.  Is this normal and what should be expected of a 45 year old car.  If this is not the norm is there some way to adjust the play out?
Re: sloppy stick shifter
« Reply #1 on: January 17, 2010, 02:30:17 »
The bottom of the shifter has plastic bushings which wear out and cause the shifter to feel loose.  Do a search on "shifter bushings". It is a common problem that the diy guy can fix .
« Reply #2 on: January 17, 2010, 11:29:36 »
Here's a good section to review...
http://www.sl113.org/wiki/TransmissionClutch/Shifter
SteveK
« Reply #3 on: January 17, 2010, 12:14:47 »
My shifter was also a little sloppy and then one day about 4 months ago without warning one of the bushings popped out.  I was able to get it home, and after figuring out what happened ordered all of the bushings from the classic center.  Under $50 delivered and about 1 hour worth of work and it shifts like brand new.   I would do it as soon as possible if I was you.
merrill
« Reply #4 on: January 17, 2010, 14:40:13 »
I watched / helped Waqas change the stick shift bushings in his car.
It helps to have a second set of hands, I think it took us all of a half an hour.
The new bushings really firmed up the shifting.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Jordan
  • Canada, ON, Jordan
« Reply #5 on: January 19, 2010, 20:21:23 »
I guess there is no way of doing this without removing the carpetting from the centre console?  My bushings need replacing by the sounds of this thread and I was hoping I didn't have to tear this up. ???
Marcus
Marcus
66 230SL  Euro 4 speed
merrill
« Reply #6 on: January 20, 2010, 02:24:51 »
If I remember correctly it helps to remove the tranny access tunnel on the passenger side
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #7 on: January 20, 2010, 03:04:08 »
Jordan, I believe the carpet around the gate is generally not glued for this very reason (and to get to the access panel Matt mentioned). Double check yours.
Ulf
« Reply #8 on: January 20, 2010, 08:29:49 »
It's one of those quick and cheap fixes that makes a LOT of difference, the carpet on the transmission tunnel is quite easy to remove - even if glued in place - and can be glued back on equally fast with contact glue - preferably in a spray can.
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
Jordan
« Reply #9 on: March 05, 2010, 01:45:34 »
Just thought I would follow up on Michael's thread talking about his sloppy shifter (I don't think my thrust rods were even attached any more).  I had the same problem and changed all of the bushings and Ulf was certainly correct.  It made a huge difference.  It was quite easy, even for a novice and mechanically challenged individual such as myself.  I recommend this easy fix for anyone with this problem.  The shifter is now tighter than my 08 Subaru and what a pleasure it is to drive. ;D ;D  Instead of hitting my knees and my passengers knees every time I changed gears, I am shifting inside a very tight circle.
Marcus
