Author Topic: Speedometer cable 1967 250sl automatic  (Read 4671 times)
jnash
« on: January 21, 2010, 20:43:50 »
My speedometer cable squeaks and chirps when the weather gets cold
The sound coincides with the speedometer slightly jumping
Is there anyway to lube it?
How do I get to it?
w113dude
Re: Speedometer cable 1967 250sl automatic
« Reply #1 on: January 21, 2010, 22:38:10 »
Yes, you can lube it, I did mine a long time ago, I don't remember exactly which end but i was able to take it apart clean the inner cable, grease it and put it back together, Check both ends one of them should be easier to un-crimp than the other.
Good Luck,
georgem
« Reply #2 on: January 21, 2010, 23:06:52 »
Hey jnash,
I posted a detailed description on this  topic before Christmas - its quite easy and can be done without taking the speedo out - with a bit of contortion, the speedo cable can be disconnected from the gear box end (on a 230manual at least ) and the inner pulled out and greased - easy peasy instant fix. The front of the car needs to be on ramps.
Cheers
George
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
jnash
« Reply #3 on: January 24, 2010, 20:14:43 »
 I will check it out
« Last Edit: January 25, 2010, 16:07:27 by Peter van Es »
merl
« Reply #4 on: January 24, 2010, 20:29:55 »
did you find a small nylon bushing on one end of the cable? if so on which end. i have a 280sl and you can pull the cable through the speedometer end without removing the housing from the auto. trans. looks the same as the tack cable perhaps someone replaced with a tack cable? it did work
