Hey Guys,
I have a new and strange problem. While completing the brake hose installation I rolled over and discovered what I thought was a wrench left by a mechanic. Reached up to pull it out and it was attached. Through my searches I have determined that this must be the speed regulator arm and it has become disconnected. My first question is the car was driven into the garage and must have been attached at that point. I do put it into neutral and roll it when working on it, but am confused as to how it could have come off. More importantly, how should I reconnect it? When I use the gear shift the arm moves and I could move the arm to match up with the nob and push it back on, but is this correct? How do I know what position the transmission is currently in? and finally how do I prevent it from happening again. I am going to try to attach pics as well. Of course it is an automatic transmission.
Jeff
