Author Topic: WOW!! What a difference  (Read 4749 times)
geezer
« on: January 22, 2010, 14:13:01 »
Just thought that I would post a fuel system success in spite of some naysayers.  In this case tenacity paid off.
I've been fussing over my '72 280SE 2.8 barn find starting on most of the cylinders and then picking up the rest within a few seconds of startup. Starting on most of the cylinders was not as much of a concern as gas washing down the cylinders from bleeding injectors. I contacted the injection shops in town to see if they would service the injectors. All said NO.
All was not lost. While prowling around the big city I spied an injection shop on a back road that was not in the Yellow Pages. As it turns out at one time he serviced the MB fuel system and was willing to give it a try.
The next day I delivered the injectors. What was disappointing is there was rust inside of the injectors. All of the injectors bled down and none had any kind of a spray pattern. The injectors are the non-serviceable type. The guy at the injection shop told me that it's no problem for his "secret" process. Good enough for me. When he returned the injectors to me he said that all of the injectors will hold 235lbs without leaking.
Well I installed the injectors last night. Oh man what a difference. The car drives much nicer than before. The best part is that it started on 6 cylinders this morning. In this case I was able to avoid buying $600.00 worth of injectors to accomplish the same thing.
scoot
  • USA, CA, Altadena
Re: WOW!! What a difference
« Reply #1 on: January 22, 2010, 14:44:26 »
What is the "secret process"?  In the age of the internet, most secrets get revealed.
Scott Allen
'67 250 SL (early)
Altadena, California
geezer
« Reply #2 on: January 22, 2010, 14:56:27 »
Scoot,
He wouldn't tell me.  All he would say is that it he had to run them on the machine for quite awhile.
« Reply #3 on: January 22, 2010, 15:06:33 »
The secret process that I used was to fill the resivior of my Bosch diesel nozzle tester with a mix of Marvel Mystery Oil and Techron fuel addative (it was for carburetors back then), and pump the contents through each of the injectors. The diesel tester has a higher pressure and volume than the gasoline injector tester and woud do a nice job of flushing the junk out of old injectors. The set of injectors in my car now are the best 6 of a bucket full of old injectors that I had accumulated. Before any one asks, no, I don't have this bucket O' injectors any more.
PnHi
« Reply #4 on: January 22, 2010, 16:02:49 »
I recall someone here talking about welding and redrilling injectors.
geezer
« Reply #5 on: January 22, 2010, 19:42:55 »
I have a couple of PM's asking where I had the injectors serviced.  Here it is.
Central Fuel Injection
John Bernardi
1128 Flowood Dr.
Flowood, MS 39232
601-933-1112
e-mail    john@cfims.net
website  www.cfims.net
