Author Topic: speedometer  (Read 3331 times)
merl
speedometer
« on: January 24, 2010, 16:11:26 »
did a speedometer repair, with help from the forum thanks. works great on the bench.  pulled the cable out somehow ended up with a small plastic bushing about 1/8" long and will just slip over the drive cable ( the inner cable that turns) automatic trans where does this go? do not have the outside cable loose from the trans, is it a spacer for that end? or just consider it an extra pt and not install    thanks merl
