Author Topic: Rust on Front bumper bolts  (Read 6313 times)
Stratis
« on: February 08, 2010, 06:35:27 »
New owner...overlooked rust on front bumper bolts...should I be concerned? is this a common problem...car was certified rust free. see attached pictures
thanks in advance
S
Re: Rust on Front bumper bolts
« Reply #1 on: February 08, 2010, 10:55:55 »
Uncertain where you have a bolt showing on your chrome front bumper? There should not be any bolt showing.
1972 MB 280CE Auto RHD 906G
2019 Izuzu DMax 4x4 Slide-on camper.
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: February 08, 2010, 11:05:17 »
Looks like the rust is on a "button" inserted in the bumper. The actual bumper bolts cannot be seen when looking at the outside of the bumper. Buttons are used to fill in a damaged pit, or an unused hole from a previously mounted light, etc. As mentioned above, these bumpers had no buttons originally.
Can get at ground level or remove the bumper to check the inside and do any cleaning needed...can get new buttons. The bumper itself does not seem to have any rust.
The bumper comes off by removing two 17mm bolts that attach each half of the bumper to the bracket. There is a center cover held on with a few small bolts. The bumper is attached to a black bracket that is bolted to the car.
The inside of the bumpers came with protective off-white paint. Can clean the inside then apply a light color Rustoleum or similar. If the final color is not correct, can use rust proof cream color spray-on paint for propane tanks. This will give the correct look and some additional protection.
If that's all the rust you have, Be Happy  :D
Richard M, NYC
« Last Edit: February 08, 2010, 11:09:28 by 280SL71 »
« Reply #3 on: February 08, 2010, 16:31:18 »
Probably from removed bumper overriders, this is fairly common...
Rust breeds rust, get those off the bumper.  Button head bolts, rusted like that, might need to be drilled out unless the hole is square and they are carriage bolts.  Take Richard's advice for prep and fix, and replace the bolts with appropriate new ones.  You'll need new bolts in chrome or stainless.
http://www.chromebolt.com/
http://www.boltdepot.com/Chrome-nuts-and-bolts.aspx
http://www.mrgusa.com/pdfs/68-72bmper.pdf
...to name a few sources.
If money if falling about you, you won the Powerball or similar, take all the bumpers off, have them repaired and rechromed. ;)
And take Richard's comment seriously: if that's your only rust--you are in very good shape.  Indeed.
« Reply #4 on: February 08, 2010, 16:42:47 »
I have more rust on my key!   ;)
« Reply #5 on: February 08, 2010, 21:33:40 »
Bumper Overriders, of course, didnt think of that. :-[
Stratis
« Reply #6 on: February 08, 2010, 22:36:08 »
Thanks.....the rust key statement drove the message home..."trivial !"...will have the bumpers removed, cleaned and do as recommended. Thanks again
« Reply #7 on: February 08, 2010, 22:41:31 »
Hey Stratis, actually I wasn't going for trivial -- just how really fortunate you are... Love to see many more pictures!
