Author Topic: Location of rear end number and ratio on 230?  (Read 5407 times)
twistedtree
  • USA, VT
« on: February 10, 2010, 23:14:57 »
I've been able to find the rear axle number and gear ration stamped on the rear end in my 280SL.  It's on the under side on a rib that goes forward from the pumpkin towards the input shaft.  But I can't find it on the 230's.  Is it in the same place?  I don't know if there's just a ton of crap the scrape my way through on the older axles or if I should be looking somewhere else.  I saw one diagram that suggested it should be on the side of the pumpkin (left side I think) around the 1:00 position.
Any guidance would be welcome.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
Re: Location of rear end number and ratio on 230?
« Reply #1 on: February 10, 2010, 23:26:39 »
Hello Peter,
It is on the back side of the main gear casting on the 230SL. In other words on the gas tank side.
There is a semi circular area machined smooth and the number is stamped on it.
twistedtree
  • USA, VT
« Reply #2 on: February 10, 2010, 23:55:43 »
Many thanks.  I'll go scraping and digging.  I'm curious to see what ratios I've got.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
DaveB
« Reply #3 on: February 11, 2010, 08:51:34 »
Probably 4.08 on a US car. Most owners seem to think they're a little low-geared - to the point where stick shift drivers start in second! Mine is 4.08 but I've only ever driven it round the block so don't really have an opinion yet.
DaveB
'65 US 230sl 4-speed, DB190
Miloslav Maun
  • Czech Republic, Praha, Prague
  • 1966 230 SL
    • http://www.pagoda.un.cz
« Reply #4 on: February 13, 2010, 18:22:53 »
This is the place where it's on my '66 230 SL
Says SL 3/75
twistedtree
  • USA, VT
« Reply #5 on: February 14, 2010, 02:22:54 »
Pictures sure are worth a 1000 words!  Many thanks.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
twistedtree
  • USA, VT
« Reply #6 on: February 16, 2010, 22:26:19 »
I found them.  The '64 has a 3.75 and the '65 has a 4.08.  Plus I have another 3.75 on a pallet in the shop.
Thanks again for the help.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
