Author Topic: radiator repaint  (Read 4340 times)
radiator repaint
« on: February 26, 2004, 17:45:02 »
Several years ago I had my radiator re-cored.  The shop did a great job in terms of performance.  However, they did not repaint it properly or at all.  I now notice some green oxidation along the seam between the core and the upper "tank."  Could knowledgable listers suggest how to deal with this?  Is there a special primer to use?  Thanks,
Don
Ohio
71 280sl
Re: radiator repaint
« Reply #1 on: February 26, 2004, 18:35:40 »
Don, could it be leaking there?  Antifreeze leaves a green residue, too.
I don't think rad shops use a primer when they repaint a radiator.  Probably any old solvent ("oil") based paint would work after a little wirebrushing to clean it up.
« Reply #2 on: February 26, 2004, 20:03:37 »
I've used oven paint from a spray can with good results on the re-cored radiator of another Mercedes I used to own. It's made to tolerate high temperatures. Use it liberally, so buy at least 3 cans.
280 SL #018260
graphic66
« Reply #3 on: February 26, 2004, 22:41:37 »
Eastwood Company sells radiator paint that works good. I painted my radiator tank and it has held up good and looks nice. Ialso touched up the top of my radiator and it worked good.
« Reply #4 on: February 27, 2004, 11:56:41 »
Don't see any leakage.  It appears to be copper or brass green oxidation.  I wasn't sure if radiator shops use acid flux that needs to be somehow cleaned off before painting.  I'd like to do the job correctly.
Don
« Reply #5 on: February 27, 2004, 12:24:36 »
Don,
I'm glad it's not leaking.  I think an acid flux is used, at least it was years ago when I watched as a radiator was reassembled.  A scrub with baking soda paste might be worthwhile.
113gray
« Reply #6 on: February 27, 2004, 16:06:32 »
I had an old MB radiator recored too. The green in my case was due to a definite leak & resulted from a reaction with the underlying brass, not green antifreeze, much as seawater or weather exposure results in a green patina on this metal. Mine was painted by the shop & continues to look OK. I have been warned, however, not to apply too thick a paint layer or too many layers as this will interfere w/ heat transfer.  -JP-
