Become a
Full Member
Emergency Contact List
Speed Bleeder
Topic: Speed Bleeder (Read 3772 times)
Hawaii
Speed Bleeder
February 17, 2010, 23:35:09 »
Has anyone ever had any experience with a product called SpeedBleeder? These are replacement bleed nipples that have their own internal check valves. The product can be found at
http://speedbleeder.zoovy.com/
. At $7.00 per nipple, this is cheaper than any OEM replacement and it seems vastly upgraded from the standard bleeder.
Associate Member
Platinum
USA, OH, Cleveland Heights
Re: Speed Bleeder
February 18, 2010, 02:44:45 »
A pressure bleeder would be more fun. When I was a tech I adapted a small air pressure regulator to work on top of a master cylinder. Hook up an air hose and bleed away.
RickM
Re: Speed Bleeder
Reply #2 on:
February 18, 2010, 15:35:05 »
The
Motive
Pressurized Bleeders are popular as well.
This is what I have:
http://www.amazon.com/Motive-Gear-0101-Universal-Bleeder/dp/B000TYJEWW
IXLR8
Re: Speed Bleeder
Reply #3 on:
February 19, 2010, 12:36:54 »
Here's an article about a home-made pressure bleeder. Much less expensive than the Amazon model.
http://www.bmw-m.net/TechProc/bleeder.htm
Joe
ericlee
Re: Speed Bleeder
Reply #4 on:
February 12, 2012, 01:12:53 »
Rick or any one,
can you please tell me if the item you post, "Motive bleeder", will fit 68 280SL? do I need to buy special cap fiting?
Speed Bleeder
