Author Topic: door check rollers  (Read 2537 times)
gnj588d
door check rollers
« on: February 18, 2010, 16:59:26 »
Should the door check rollers be greased?.Thanks Mike
Larry & Norma
Re: door check rollers
« Reply #1 on: February 18, 2010, 20:45:31 »
Hi
My guess would be no, you want the roller to turn, not slide on the same spot. That is when they wear.(They have a roughened surface to grip) The nylon type material should
be self lubricating on its mounting bolt so i wouldn't grease that either. Just my thoughts.
Larry
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
gnj588d
« Reply #2 on: February 18, 2010, 21:51:12 »
Hi Larry .thanks for the reply I think you are correct mine had a flat spot on the roller because they where sliding not rolling,no more greasing.Cheers Mike
