Author Topic: Front Axle Sub Frame  (Read 4935 times)
Irish280SL
« on: February 22, 2010, 18:03:15 »
I am looking for a front axle / sub frame for a 1969 280SL, has anyone any idea if this part
would be common to any other Mercs of this era or is it unique to the 280SL?
w113dude
Re: Front Axle Sub Frame
« Reply #1 on: February 22, 2010, 19:51:55 »
I have w113 and w111, w108 as far as I can see they are all the same.
« Reply #2 on: February 23, 2010, 05:52:20 »
Yes, I am sure that some of the W111 and W108 and possibly the W110 chassis MB sedans of the era are basically the same. The coil springs, and subframe mounts are different.
I would have someone run a check on the model and part numbers for any uints you come accross to make sure they are the same.
Eminent
« Reply #3 on: February 23, 2010, 22:16:53 »
Correct. Looking at EPC-net the W108,109, 110, 111 and 113 have the same subframe.
Benz-number A111.330.30.42
When i do a search at that partnumber i see that this subframe is also used for the W112.
« Last Edit: February 23, 2010, 22:30:10 by Eminent »
« Reply #4 on: February 23, 2010, 23:03:42 »
Thanks Eminent,
Be careful with the W109 a lot had air suspension and all the W112 had air suspension. The basic subframe would be the same but a lot of the bolt on parts like the A arms etc. are different.
Eminent
« Reply #5 on: February 24, 2010, 14:02:00 »
You're right. I'm only talking subframe in my previous post.
Irish280SL
« Reply #6 on: February 27, 2010, 18:17:18 »
Thanks for the reponses, I have found one off a W108 that I can use.
