Per - I am pretty sure my rebuilt engine has an 08 camshaft. I never did get around to installing my euro (09 code I suppose) camshaft that I got from SLS last January. I will measure the diameter of the cam bearing journals next time I am at the garage.
It's true that the hotter cam produces more HP, however the extra power comes in only from about 5,000 RPM and up. There is an original factory diagram in "Vom Barock zur Pagode" by Gunter Engelen, page 185. It shows that, at 5,500 RPM, the difference is 15 HP; at 6,200 RPM it's about 20 HP. But, to my surprise, it also shows that, up to 4,500 RPM, there is hardly any difference; in fact, below that point the milder cam is shown to produce slightly more power! So only if one really revs the engine quite hard, as in traffic-light hot-rodding, or racing or rally driving, and at top speed does the euro cam 'pay off'.
I suspect that other tuning details such as the valve & ignition timing, fuel/air mixture settings, state of the linkages, engine compression and all of those other things, will influence performance more than the cam.
Yesterday I floored my car once more and, driving top-down, I very rapidly reached close to 115 MPH / 185 KPH with the car still accelerating when I let off the gas. For me this is hot enough!
