Author Topic: Soft top lid seal  (Read 3858 times)
Larry & Norma
Soft top lid seal
« on: March 04, 2010, 14:27:56 »
I am in the process of replacing the soft top lid seal. There is little if any evidence of glue on the old seal.
Should the seal be glued or wedged in?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
w113dude
Re: Soft top lid seal
« Reply #1 on: March 04, 2010, 18:29:59 »
The seal should be glued in place, otherwise water will sip through the channels & eventually end up inside the cabin.
« Reply #2 on: March 04, 2010, 20:05:56 »
Most of the reason why this seal needs replacing is that the soft top material rubs on the rubber whenever the top is being lowered and raised, quickly destroying that section of the seal.  Once you have replaced the seal, take the time to fabricate a pair of plastic "guides" to ease the soft top material by the rubber seal without damaging either it or the top material itself.  I use two large heavy duty zip-lock bags for this purpose, others make something out of gallon milk jugs - it doesn't matter how pretty the "guides" are, just that they are effective!  They can be stored in the empty compartment when the top is up and folded over the top frame on each side before closing the lid when the top is stowed.
Via Manci
« Reply #3 on: March 05, 2010, 03:27:08 »
How  about a picture of the guide.  It is hard for me to visualize what you mean.  Thanks
« Reply #4 on: March 05, 2010, 05:10:58 »
Here is my version of a guide known as the Pagoda Flap. Kind of lousy pictures but should get the idea across. Patent pending... :)
Ulf
« Reply #5 on: March 11, 2010, 11:15:33 »
What a simple, yet brilliant idea!
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
