Author Topic: 230SL engine or not? Ask the 230SL detectives  (Read 4979 times)
perry113
  • USA, NY, Rensselaer
« on: March 06, 2010, 06:04:35 »
Maybe I'm wrong, but the casting features on the valve cover of this engine look like those you see on a 250 and 280 series engine.
Did they have 230 series engines with this later style valve cover casting?
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Re: 230SL engine or not? Ask the 230SL detectives
« Reply #1 on: March 06, 2010, 06:14:59 »
Perry -- does this seem to be the same as yours??? (looks the same to me)
perry113
« Reply #2 on: March 06, 2010, 15:16:33 »
The picture you posted looks like a 230SL. I base this on the valve cover casting.
Take a look at this picture. I marked the provisions I question in the valve cover casting that would lead me to believe my original posted picture is a 250 or 280 series engine.
Did any 230 series engines has these provisions?
Peter Perry
1970 911T Bahia Red
« Reply #3 on: March 06, 2010, 16:33:03 »
I think the banjo fitting breather tube was replaced with the rubber elbow during the 65 model year.  280sl's have a 1/4 twist oil cap. My 66 230 has the same valve cover as the one in your photo, The notches you hilighted were for improved crank case vent baffeling.
« Reply #4 on: March 06, 2010, 18:06:07 »
What are the VIN and Engine #s of your car?
Jordan
  • Canada, ON, Jordan
« Reply #5 on: March 06, 2010, 19:28:22 »
Perry,
See attached pic.  Mine is a 1966 230SL and it also has the indents and it si original.
Hope this helps. :)
Marcus
66 230SL  Euro 4 speed
perry113
« Reply #6 on: March 06, 2010, 22:48:33 »
Then my question is answered.
Thank you.
Peter Perry
1970 911T Bahia Red
menesesjesse
  • USA, MD, Indian Head
« Reply #7 on: March 07, 2010, 02:50:15 »
If your car is a 65 I would think your valve cover looks like mine.  The rubber breather was later then 65 I believe.  I have a late 65 and it was just rebuilt.  The spark plug wire frame is also missing .  I attached my photo for reference.  Hope it helps.  Your valve cover is definitely right.
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
jacovdw
« Reply #8 on: March 07, 2010, 09:42:11 »
The change in the breather line was introduced in December 1965 and that included the fitting on the valve cover.
