Hi Everyone.
We have taken the 1966 230sl out of gargage after three years of sitting. Car started right up. Drove it a mile to mechanic. Had them change rear brake shoe pistons, shocks, clutch sleeve pump, water pump, all brake lines, and all front bushing & tire end rods, flushed radiator, and tune up. Man, anything with fluid basically died.
I told the mechanic to drain fuel and clean gas tank. Several days later, mechanic stated fuel "smelled fine". When I picked up the car and drove home, the car died. We flatbedded back. Mechanic said he saw black fuel in the canister that holds the fuel filter.
Today, when I called to pick up car, mechanic said fuel pump has stopped working. He tried direct power and the pump was silent.
Reviews/comment here indicate to me that the pump is probally "gummed Up" . It is a bosch fuel pump. I purchased 9 years ago, but only 865 mile in that time.
Below are some fuel pumps for sale. I know the Bosch for $600., but does anyone know the other brands?
On Monday, we are going to try to reverse the polarization to see if pump will break free and then clean with a flush.
Any advice? Thanks and I hope all are having a great weekend.
+ enlarge image Carter Fuel Pump
App: 1963-1966 Mercedes Benz 230SL
Brand: Carter
Part #: P60504
Notes: CARTER FUEL PUMP, IN-LINE, NEW -- Electric; A high quality, direct fit OE replacement fuel pump.
Type: Direct OE replacement
Condition: New
Operation: ElectricPrice: $60.70
Quantity
Make Model Year Range Chassis/Engine
Mercedes Benz 230SL 1963 - 1966 Base; 6Cyl 2.3L GAS, CARB;
Bosch Fuel Pump
Brand: Bosch
Part #: W0133-1830737
Notes:
Condition: New
Warranty: 12-month or 12,000-mile warrantyPrice: $601.54
Quantity
Mercedes Benz 230SL 1963 - 1966 All Submodels; All Engines;
+ enlarge image Beck Arnley Fuel Pump
App: 1966 Mercedes Benz 230SL
Brand: Beck Arnley
Part #: 152-0576
Notes: BECK ARNLEY FUEL PUMP, NEW -- Electric; Comes with new strainer and any necessary hardware and hoses; Meets or exceeds OE specifications within OE specified flow rates to ensure optimum performance; Calibrated and tested; No splicing of wires or connectors needed; Rerouting of fuel lines or changing of fittings is not necessary; With Beck Arnley's limited 90-day or 4,000-mile warranty.
Condition: New
Operation: Electric
Warranty: Beck Arnley's limited warrantyPrice: $82.75
Quantity
Mercedes Benz 230SL 1966 Base; 6Cyl 2.3L;
he mechanic that
