Author Topic: Throttle Body.  (Read 3373 times)
tel76
Throttle Body.
« on: March 14, 2010, 09:22:55 »
Has anyone removed the throttle butterfly and spindle from the throttle body to have the aluminium body bushed to take out the excessive free play?
If so, is there a pair of steel bushes in there or does the spindle operate directly in the aluminium housing?
Eric
Re: Throttle Body.
« Reply #1 on: March 14, 2010, 11:17:07 »
Hi Eric,
Probably not much help to you ... but I had a small amount of play in my throttle body.  I sent it off to Mr. Jerry Hjeltnesf (Escondido, California) 760-746-9966.
He did an excellent job restoring the entire body and eliminating the "play"  He also installed all new pipe connection points.
pj-tigger
Re: Throttle Body.
« Reply #2 on: March 14, 2010, 21:50:18 »
The spindle sits in bronze bushes & behind the bush there is an "O" ring (that has gone rock hard !). The bushes can be replaced but there not a stock size so have to be made.
tel76
Re: Throttle Body.
« Reply #3 on: March 25, 2010, 08:25:03 »
I have removed the butterfly and spindle from the throttle body and have found that the spindle is very badly worn.
Does anyone have a part number for this item or a good replacement?
Whilst the bushes are easy to make the spindle is not so.
Eric
