Author Topic: Painting hubcaps  (Read 8175 times)
perry113
  • USA, NY, Rensselaer
Painting hubcaps
« on: March 22, 2010, 00:02:05 »
I have been in desperate need to paint my center caps on the 230SL. I finally bit the bullet and painted them on Saturday. Instead of using a stencil I taped off the non painted chrome areas using flexible rubberized masking tape. The whole thing took 4 hours to do.
They came out fantastic.
My car now finally has colored caps to match its beautiful Light Ivory paint.
« Last Edit: April 28, 2010, 02:17:32 by perry113 »
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
menesesjesse
  • USA, MD, Indian Head
Re: Painting hubcaps
« Reply #1 on: March 22, 2010, 02:36:46 »
Great job on the hubcaps.  They look great.
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
Ulf
« Reply #2 on: March 22, 2010, 12:31:53 »
That just encouraged me to do the same thing, did you use a scalpel to cut the tape in place or was it flexible enough to follow the rounded contours?
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
« Reply #3 on: March 22, 2010, 18:17:40 »
instead od trying to follow the coutours of the star and ring with the tape, I just run straight pieces of masking tape over the entire area, trim it with an X-acto knife and peel away the area to be painted. This way takes less than an hour to do all 4 wheels.
w113dude
« Reply #4 on: March 22, 2010, 22:29:22 »
Good job Peter!
perry113
« Reply #5 on: March 28, 2010, 04:07:54 »
Ulf
It's special flexible tape and bends beautifully.
Peter Perry
1970 911T Bahia Red
« Reply #6 on: March 28, 2010, 12:56:35 »
I also use Al's flat tape process.
I usually lightly sandblast the untaped areas after masking and before priming so the primer gets good adhesion. I also use a "etch" primer.  The same tape job works on the sandblasti and the painting. Be gentle.
The secret to a good job is to use just enough paint and primer to do the job. A very light coat of primer and just enough paint to cover is best.  Heavy paint build up causes heavy, thick paint edges when the masking is removed.
perry113
« Reply #7 on: March 31, 2010, 13:34:23 »
I scuffed the areas to be painted with a red 3M scuff pad (320). You take off the tape within 45 minutes after painting. If you wait too long you can run into a problem of pulling off painted surfaces.
I think the flexible tape is called fine line. It's blue and comes in several widths.
Best of luck to all who are going to do the same.
Cheers
Peter Perry
1970 911T Bahia Red
Ulf
« Reply #8 on: April 27, 2010, 09:08:28 »
I gave up on finding that special, flexible tape and used regular masking tape and a fine scalpel - that worked fine as well, at least I'm quite proud of the result as I'm not usually very good at doing stuff like that :)
2008 Jaguar XF 3.0
2005 Mini Cooper
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #9 on: April 27, 2010, 17:09:41 »
And now you, in turn, have given me motivation. Thank you.
1998 BMW M-Rdstr Estoril Blue
Ulf
« Reply #10 on: May 03, 2010, 06:45:08 »
You're welcome - have fun! ;)
2008 Jaguar XF 3.0
2005 Mini Cooper
