Author Topic: Overflow tank bracket  (Read 2815 times)
« on: March 22, 2010, 18:59:19 »
Well, it looks like my little bracket that secures the coolant overflow tank to the firewall has broken off of the tank. Any ideas on how to reattach it?
graphic66
Re: Overflow tank bracket
« Reply #1 on: March 22, 2010, 20:52:46 »
Take the tank out, completely clean to bare brass where it has broke apart. You can then solder it back together. It will require radiator solder 50/50 acid core is best and some flux. I just use a propane torch and a wet sponge or rag. It will take basic soldering skills. Just make sure you have bare brass where you want the solder to go. I like to tin both pieces apart, get them completely covered with solder, and then put them together and heat them until the solder flows and the parts go together. Keep your wet sponge or non synthetic rag handy to wipe down and cool your pieces. Watch getting the tank to hot near the seam, you may melt the solder out there, no problem, just resolder the seam also. It is real easy to fix. You can get the best looking paint at Eastwood Co. for the tank and radiator. It is called radiator paint. It looks better than the high temp paint usually sold for some reason.
« Reply #2 on: March 23, 2010, 16:35:25 »
Well Graphic66, I was hoping to hear double-sided tape! but sounds like yours is the better way to go. Thanks!
Kind of wish this had happened in December and not right before "the Drivin' Season kicks in"....
