Author Topic: Rear brakeshoes 1967 230SL  (Read 3232 times)
Bobo
« on: March 22, 2010, 19:05:51 »
Hi has anybody replaced the rear brakeshoes on a 230SL without the special tool for compressing the preasure spring behind the two shoes? If so how on earth did you manage it?
I am struggling.
JimVillers
  • USA, VA, Virginia Beach
Re: Rear brakeshoes 1967 230SL
« Reply #1 on: March 22, 2010, 19:23:41 »
Bob .... All auto parts stores have a brake spring tool that works well, cost about $15.
Jim Villers
jameshoward
« Reply #2 on: March 22, 2010, 22:09:13 »
I am struggling.
Yes. It's do-able, just fiddly. The best thing not to do is put the things on the wrong way around, that way you only have to do it once. I didn't use a special tool, but recall it was a bit of a pain. Can't remember how I did it, as I didn't have a plan or any prior knowledge of the brake except what's on the site.
JH
James Howard
1966 LHD 230SL
230slhouston
« Reply #3 on: March 23, 2010, 02:09:29 »
I did my brakes without buying  a special tool, I made up one. I took a sturdy angle iron used an angle grinder to cut a notch on one end, wrapped a rag as a handle and installed the springs. The angle iron was small enough not to foul anywhere. Took me half an hour of trying and two minutes with my tool.
Cheers
xcashewx
« Reply #4 on: March 23, 2010, 07:21:50 »
i used a pair of vice grips in one hand with the socket in the other hand, pushing in while turning the screw. bit tiring but got the job done
