Author Topic: accelerator pedal pivot  (Read 8469 times)
230SL
« on: March 24, 2010, 00:50:36 »
Does anyone have a picture of the accelerator pedal pivot which i think is welded to the floor board? The car was started as a project a long time ago with no evidence of where anything goes pictures and distance from firewall to welded stop would be a plus. I know the newer Mercedes 90's used the plastic at the bottom of the pedal as a pivot but this seems to have 2 sphere like objects like those of the accelerator linkage or kick down linkage on newer Mercedes 90's.
Re: accelerator pedal pivot
« Reply #1 on: March 24, 2010, 01:33:14 »
A bracket with two pins is welded to the floor.  The center line of the bracket  is 14" from the left frame rail and 21 1/2" foward of the front seat rail.  That is x/y location..measure w/carpet.  The pins have round balls at  the top that fit  the base of the rubber gas pedal.
230SL
« Reply #2 on: March 24, 2010, 02:33:30 »
Wow that was quick and precise!!! :o
« Last Edit: March 24, 2010, 04:43:23 by 230SL »
« Reply #3 on: March 24, 2010, 10:08:06 »
Here is the only one I could find....
« Last Edit: March 24, 2010, 10:12:42 by bpossel »
graphic66
« Reply #4 on: March 24, 2010, 15:16:45 »
Make sure the pedal hits the kickdown switch when fully depressed. That is very important and critical to positioning.
« Reply #5 on: March 27, 2010, 22:25:08 »
And make sure you use the correct and now difficult to locate pedal!
230SL
« Reply #6 on: March 29, 2010, 18:53:20 »
Thanks for the quick replies and pictures its really going to help out alot.  I actually ended up ordering the bottom support and pedal from K & K manufacturing so far they have been very helpful and knowlegable in helping me get parts for my 230SL. Still cant't belive the pedal from Mercedes Benz Dealer was $580.00 :o and they no longer make the bottom bracket al least here in Westchester NY thats the story.
« Reply #7 on: March 29, 2010, 19:21:29 »
Try one of the regular suppliers for 113 610 0253.
Seems to be available in Europe...
w113dude
« Reply #9 on: March 30, 2010, 11:18:45 »
I  bought mine for under $30.00 from www.kkmfg.com fits perfect.
BABAK
  • USA, CA, Valencia
69 280sl dark olive automatic
71 280sl bronze brown
70 280se coupe light Ivory
59 190sl
61 190sl
www.vintageeuroparts.com
