Author Topic: Fitting Getrag 5 Speed Gear Box  (Read 60484 times)
Re: Fitting Getrag 5 Speed Gear Box
« Reply #25 on: September 05, 2010, 19:56:50 »
Hi Jay and Peter,  Thanks for info,  I am in Switzerland at the moment and getting ready to attend the Euro Tour week after next but left my car with a good mechanic to work on fitting the gear box whilst I am away for the month of September. I just ran out of time to do anythingmyself so hopefully all will go well.  Glad to know that I will not need to refit my old 4.08 axle.
1972 MB 280CE Auto RHD 906G
2019 Izuzu DMax 4x4 Slide-on camper.
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #26 on: September 14, 2010, 18:07:04 »
I've just fitted one of these for a forum member and I have to say that it's not difficult BUT it did present quite a few challenges due to the unknown and experimental nature.
Firstly obtaining a box here in the UK is very difficult. The first one I obtained turned out, after I'd modified it, to be a dog leg sport box despite me seeking assurance from my supplier that it was an O/D box. As a dedicated Mercedes man I know nothing of BMW boxes and learnt that the two boxes are externally very similar but there are visual cues once you know what to look for.  It was quite a struggle to obtain the correct box and then I ended up buying two as they're so rare.
Installing the speedo drive requires removal of the rear cover and this requires special tools.
Obtaining the correct propshaft coupling also proved to be a bit of a drama.
The first incarnation of the modified selector rod fouled the propshaft coupling and had to be re-made.
Having the speedo cable made was a bit hit and miss as I didn't have a BMW one to offer as a sample so had to take measurements from the box and create a drawing (I ordered two cables so if I need anymore I can simply send my spare off to be replicated)
The speedo cable cotter pin that secures it to the box was also a last minute drama; a) because I didn't have one and so had to make one and b) because the o/haul company hadn't lined up the drive shaft properly and so even when I did make the pin it wouldn't locate properly and so I had to engineer a completely different fastener.
Lastly I made some mods to the fitting kit as supplied by Mark to make installation simpler.
The vehicle owner is coming back on Friday for some fettling but he reports that the high speed cruising is much improved, if a little noisier than he was expecting. I don't know yet but it sounds like there may be a problem with the box despite my insisting that we have it o/hauled before installation.
When I get time I'll write some more on the subject, including a definitive list of parts.
For the  moment however I'd say it's not a job to be taken on lightly.
jaymanek
« Reply #27 on: September 14, 2010, 19:26:25 »
Hi Colin,
Well done on getting it finished.
My comments would be to get the box fully redone by Allgears in nottingham next time. This way the speedo drive will already be done and the box completely refurbed.
As for the speedo cable, speedy cables have the exact part numbers you need, there should have been no messing about here. For a LHD its 211556.
Preparation is the key with this job. The conversion itself takes no more than a few hours.
I also had trouble with the gear linkage, I tried various angles until I got it just right and then welded the rods together.
The biggest pain is cutting out the transmission tunnel behind the hand brake.
For your info, my fully refurbed and guaranteed box is a little whiney too. The old 4 speed was completely silent. But its not noisy enough to warrant my time removing it again.
You are right though, its not a job for the inexperienced or those without a ramp!
« Reply #28 on: September 17, 2010, 07:04:31 »
Quote
Thanks Jay, is this a BMW part number or Speedy cable's part number?
And why LHD, isn't that going to be too short for RHD?
Colin
jaymanek
« Reply #29 on: September 18, 2010, 23:16:55 »
Thats Speedy Cables..
LHD the one I kept a note of for my car, im sure speedy cable will have the part number for the associate RHD cable.
« Reply #30 on: October 13, 2010, 20:33:30 »
A simple question and an embarrassing one to ask but....
After fitting the getrag into the car, I am unable to locate reverse.
Question before I have the gearbox in bits, what is the pattern for gears on the box, just to make sure I am not doing something really silly??
« Reply #31 on: October 13, 2010, 21:55:54 »
It's next to 1st unless it's different from mine.
Same pattern as the stock four with the fifth next to third.  I used a four speed knob and had it modified by a jewelry engraver.  Once it was done it was covered in a thick clear shell.
Here's the photo of my shifter knob.
« Last Edit: October 13, 2010, 22:37:17 by hauser »
« Reply #32 on: October 14, 2010, 00:46:38 »
Thanks Fernando, Must do the same for the gear nob.
Took the box out and opened it and appears there was a poorly fitted item, hopefully it will work this time.  What I must do when its put back in is to make sure that the gear lever is the right way round as picked up by another member  in an earlier post of a photo of my interior as there is a slight kink in the gear lever that should sit forward. Maybe you have the same problem with the lever the wrong way around?
Will send a photo once done.
jaymanek
« Reply #33 on: October 16, 2010, 19:08:50 »
Ok spill the beans, where can I get that knob??!
« Reply #34 on: October 16, 2010, 19:38:54 »
Get a new stock 4 speed knob.  Take it to an engraver and have them add a 5 and make it look like the rest.  I then took it to someone that does cypress clocks.  These clocks are coated in a thick clear epoxy resin and had the same done to mine.  The original knob being that it was twenty years old (post Getrag install) had worn off numbers.  I didn't want the same thing to happen to mine and came up with the epoxy shell coating.  I think it turned out well.
The epoxy coating can be done at home but the fumes are quite hazardous to your health (warning label on the can).  I didn't want to mess with this because of my kids.
jaymanek
« Reply #35 on: October 17, 2010, 11:16:31 »
Excellent! Has to be done... now wheres my nearest engraver...
« Reply #36 on: October 19, 2010, 08:09:32 »
I am a happy man tonight.
I finally got the gear box back in the car after several tries.  There were several modifications that were needed to get it all to fit properly including using some spacers under the Gear Box Mounting to get the mount to sit 8mm lower and to get it to fit which then meant that I did not have to do any body modifications in the tunnel.  Had to undo the engine mounts to get the engine to move a bit to allow it to be moved into place and a couple of oblong bolt holes to allow variation in the fitting of the new tail shaft.
Have had a drive and its a dream. The Getrag box from the BMW M3 has nice crisp short throws and the box is as silent as any new car which is lucky as I did not have it overhauled as it was supposedly in good condition and all I am now awaiting is a new speedo cable due to a different end to the speedo worm drive I fitted in the gearbox in place of the electronic sender. I don't know the full variation in speed to revs at this point.  What I do know is that the 3.46 rear end with the 5 speed is just fine and I will not change back to my old 4.08 diff.  Maybe I can sell it to pay the cost of the Getrag!!  Hopefully next week I will get the speedo connected and can get the readings and what it has done to the revs as I want to also replace a couple of the hosed that are leaking oil before taking it out for a long drive.
For Ashim, I have left the gear lever sitting the wrong way round as it sits better rather than the kink toward the front that makes it sit up a bit high. Will photograph it when I get the car all together and back home.
And I must get an engraver at one of the Malls to add the 5th gear position.
Will add some photos hopefully next week.
« Last Edit: October 19, 2010, 08:21:07 by Garry »
Franz W
Getrag 5 Speed Gear Box 5-speed knob
« Reply #37 on: October 20, 2010, 07:50:33 »
Hallo,
do you know that SLS sells 5-speed knobs in the original design in black or white ?
best regards Franz
Doing the Getrag 265 conversion in my 230SL in Austria after having solved some problems with my new engine. And reading this thread very interested.
« Reply #38 on: October 20, 2010, 10:48:25 »
But the local engraver at the mall does it for $10  ;) ;D ;D
Franz W
« Reply #39 on: October 20, 2010, 12:23:41 »
Hallo,
i see.
regards Franz
« Reply #40 on: October 20, 2010, 14:11:57 »
The ZF 5 speed knob has a different pattern.
mkbull
« Reply #41 on: October 20, 2010, 17:03:00 »
Hi Garry, pleased to hear you got the gearbox in successfully, I am interested in why you needed to drop the mount 8mm - since I am pretty sure the mount I sent you puts the gearbox in the correct alignment.
I suspect the setup will cope with very large "out of alignment" due to the flexi coupling and central uj.
Most of these old cars are driving around with well worn rear gearbox mounts and this will have the same effect as your set up ie. drops the engine at the rear.
You may just encounter a couple of problems - one is the long term additional stress on the flexi coupling due to the out of alignment and secondly you will probably notice that you have difficulty getting your rocker cover off, (this can be overcome by simply jacking your engine up slightly at the rear of the gearbox if you ever need to remove the valve cover)
Great solution on the 5 speed knob (i purchased a standard 5 speed knob - figured i would just put up with it being incorrect) but seeing hausers idea - i must get one of those for myself.
Mark
« Reply #42 on: October 20, 2010, 21:23:06 »
Hi Mark,
I already had problems with the rocker cover removal after fitting new engine mounts and always had to jack the engine a bit to remove.  The box was just too tight in the tunnel and I noted that others have made some alterations in the metal work which I did not want to do so the easiest was to lower it a bit and then realign the whole thing hence other adjustments that were made for the tail shaft. It runs a smoothly but as I said I have not had a chance to take it out on a long run yet.
« Reply #43 on: April 28, 2011, 01:11:11 »
For anyone contemplating this swap most Getrag 265 gearboxes do not have a speedometer drive. the speedometer gears to add the speedo drive to a Getrag 265 are about $300USD from BMW. However the gears are the same from any Getrag in a BMW. Bavaria, E9 CS coupe, Early 5 series etc.
« Last Edit: May 12, 2011, 02:28:37 by Shvegel »
« Reply #44 on: April 28, 2011, 01:40:30 »
I did the change, its a single worm drive that fits in the position that the electronic drive comes from and yes it is very expensive if you want to buy one from BMW.
You will also need a new speedo cable as the end fitting into the gear box is different to the MB but not that expensive.
And,  it is fantastic to drive with the 5 speed and a 3.46 rear end, a true overdrive.  Plays havoc with the speedo calibration that I have not resolved yet.
« Reply #45 on: April 28, 2011, 01:48:50 »
I had Mark supply the cable when he sent the kit so I'm covered there.
« Reply #46 on: April 28, 2011, 05:53:58 »
As you refit the gear box, watch for the clearance on the LH side of the tunnel.  I had limited clearance and rather than change the tunnel shape to have it fit, I used some spacers on the support bracket that worked just fine and gave the needed additional clearance.  I suspect the rubber mounts are just a fraction too high and may well compress with some time and the spacers removed.
« Reply #47 on: May 02, 2011, 21:58:28 »
I suggest that anyone contemplating this should definitely have the gearbox overhauled first.
I've had enormous problems in getting a quiet gearbox that selects all 6 gears, including an inability to select reverse after the gearbox had been to a second "specialist" for overhaul. Luckily the customer doesn't use the car in winter but that's just as well because it's taken a full seven months to get a satisfactory outcome. That said the result is excellent!
« Reply #48 on: May 02, 2011, 22:17:25 »
Stick,
I had a similar problem with my box not selecting reverse.  I took it to a gearbox specialist who said that it was a minor problem with the selectors and changed me $75.  Was fixed in 1/2 hour.  Maybe just luck but I agree you want a good gearbox to start otherwise you can waste your money.  Luckily I got mine from an M5 that had been written off with only 15,000km on it.
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #49 on: May 03, 2011, 01:35:58 »
The electronic to mechanical speedometer and the calibration problem can be resolved with the Abbott Cable-X box.  It uses the electronic pick-up off of the side of the transmission and contains an electric motor that drives the speedo cable.  I paid just under $300 for it and had a cable fabricated by a local shop for $28.  The speed of the motor is controlled with dip switches.  It comes with a chart for a starting point, and with a GPS, and some trial and error, you can dial in the speed exactly, no matter what the rear gear ratio or final transmission gear ratio.
I mounted the box under the driver's seat with Velcro.  The speedo cable runs under the carpet in one of the grooves in the floorboard.  There is already a hole in the crossmember under the seat that allows the cable to pass through.  I connected the power wire to the back of the fuse box and ran that wire under the carpet in the corner of the floorboard.  The wire for the pickup can run under the carpet and through the shifter hole and to the side of the transmission.  If you do the transmission now, and the rear end later, you just flip a couple of dip switches to re-calibrate the speed.  You can even compensate for tire diameter.
Unfortunately, this leaves you with no excuses for the local constabulary.
