Author Topic: Lubricant for Heater lever  (Read 2951 times)
asjmplisson
« on: April 01, 2010, 02:09:54 »
Can someone let me know the type of oil or lubricant I need to use for the Heater levers ?
What about the cable ? which Lubricant and oil need to be used ?
Thanks for the help ...
Bernd
Re: Lubricant for Heater lever
« Reply #1 on: April 01, 2010, 05:03:51 »
I used a silicone grease inside the cables. Pull the wires out, note their orientation, polish them with a little polishing compound, then I injected a little lithium grease down the openings. works great. On the heater levers also, after I disassembled the mechanism, cleaned everything, polished the plastic, I used some lithium grease as well as my understanding is that it will not attack the plastic (however, you might read that older petroleum based formulations of lithium grease "may" attack plastic).
The stuff I like is called GUNK  Liquid wrench White Lithium Grease.
