Author Topic: Correct color on exhaust manifolds for 280SL 280SE  (Read 3236 times)
perry113
  • USA, NY, Rensselaer
« on: April 09, 2010, 20:29:46 »
I am in the process of restoring my exhaust manifolds on project W111 1970 280SE.
I will sandblast and refinish using Bill Hirsch manifold paint.
My question is what color were they originally. My color choices are black, gray and silver.
Cheers.
PDP
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Re: Correct color on exhaust manifolds for 280SL 280SE
« Reply #1 on: April 09, 2010, 23:16:13 »
Peter,
I too am curious what the correct color is. As a more durable alternative, you might consider ceramic coating the manifolds. I have used exhaust paint in the past and it will eventually begin to degrade and rust through. Ceramic coating should last a lifetime.
« Reply #2 on: April 09, 2010, 23:20:39 »
Hi Peter,
as far as the 280SL color is concerned the answer is right here and I assume it would apply to a 280SE:
http://www.sl113.org/forums/index.php?topic=6139.0
I have used Dupli-Color® High Heat Paint with Ceramic for the intake and exhaust manifolds- baking it in 3x in a gas grill as recommended - and it holds up very well.
« Last Edit: April 09, 2010, 23:31:21 by 66andBlue »
