Author Topic: The 280 SL with the 2 carburetors AGAIN  (Read 4493 times)
tesandori
« on: April 17, 2010, 21:26:37 »
Well, can I buy an original 280 SL engine and how much would it cost ? (of course rebuilt one)
The car has been perfectly rebuilt, except that it doesn't have a fuel injection engine.  Also changing gears is a bit "crude".  Crude in a sense that your hand has to carefully guide the stick shift into gear ;)
PLEASE HELP AGAIN
Re: The 280 SL with the 2 carburetors AGAIN
« Reply #1 on: April 17, 2010, 23:05:49 »
According to the Metric Motors web site: http://www.mercedesengines.net/products.asp?cat=26
it will cost you $7,100 + engine core (or $1,500) + shipping.
tesandori
« Reply #2 on: April 18, 2010, 06:07:38 »
Thank you. :)
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: April 18, 2010, 08:53:28 »
But that won't get you the injection pump, intake manifold, throttle body, injectors and plumbing, cold start valve, etc.  You would need to find a complete engine or maybe a complete car (like a sedan) to get tha stuff.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
graphic66
« Reply #4 on: April 18, 2010, 19:12:59 »
Probably less costly to buy a complete car like the one you will end up with when done.
Ulf
« Reply #5 on: April 20, 2010, 07:41:18 »
The sloppy gearshift is probably a case of worn bushes in the shifter (assuming its a manual), they are cheap and easily replaced.
Good luck with your engine search
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
RickM
« Reply #6 on: April 23, 2010, 17:44:16 »
I don't know what the cross compatibility might be but here's an option for sourcing www.car-part.com (See below for countrywide search)
I'd also scour Craigslist for components and parts cars.
