Author Topic: Front wheel arch  (Read 2887 times)
Larry & Norma
Front wheel arch
« on: April 22, 2010, 18:37:20 »
Just had a good look under the front wheel arches and discovered a couple of problems.
Firstly so called 'professional work' is c..p! The underseal seemed to be a place to store water!
There is only one weep point on the bulkhead/firewall area on one side, the other has none.
Would you suggest I drill a hole up into this area.
Is it possible to gain access to this cavity to put waxoil etc in? Are there grommets.
Stripped the bad underseal and luckily the panels were not too corroded underneath so have resealed.
It's just that cavity that bothers me.
Larry
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Larry & Norma
Re: Front wheel arch
« Reply #1 on: April 23, 2010, 15:47:54 »
Just found the links to this topic under 'drains'. First class info as usual. This really is a great site!
2023 Ioniq6
2005 C230
