Author Topic: The "courtesy lamp" ...  (Read 5359 times)
LXIX SL Rookie
« on: April 23, 2010, 21:38:37 »
Hey, U.S.-based Pagoda Top Nuts ...
Where can I find the correct BULB for the courtesy lamp tucked under the dash ... ?  Is it something I can buy locally ... ? ... or ... ?  Thanks!  Pete N.
Jim Donati
Re: The "courtesy lamp" ...
« Reply #1 on: April 25, 2010, 23:54:16 »
There's a light in the car?
I would be interested in knowing where this courtesy light "under the dash" you speak of is located?   The only interior light I am aware of in my 1970 280SL in the map light in the glove box door.
If there is another light that illuminated the interior of the vehicle, I would appreciate some detailed information describing its location.
thanks
Jim
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #2 on: April 26, 2010, 00:42:05 »
here is a picture of the light
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Jim Donati
« Reply #3 on: April 26, 2010, 03:05:18 »
Badali:
Wow, it was right there under my "nose" just as you pointed out.  I moved the switch out of the OFF position and into the position that activates the light when the door is open.  It actually works.
I love this site!
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #4 on: May 02, 2010, 21:39:13 »
Jim Villers presented several options for LED replacement lights at both of the last PUBs.  I believe he had one for the courtesy light that produces a much brighter light at the same power.  However, I can't find the handout.  Perhaps someone else has it handy.  Other wise, you could pull the number off of the old bulb and see if there is a cross reference on the Daniel Stern lighting web site.
« Reply #5 on: May 09, 2010, 16:59:36 »
Jim Villers handout is here: http://www.sl113.org/wiki/PUB/Start
douglas dees
« Reply #6 on: May 09, 2010, 17:45:37 »
Does anyone have a list of LED bulbs for replacement for a 1969 280SL. I don't know which ones will fit my tailights or parking lights. Is there a replacement LED for the original Osram bulbs for the European headlights?
Doug Dees :)
« Reply #7 on: May 09, 2010, 21:19:59 »
Although this page does not give LED replacements, it may help in your search for them:
http://www.sl113.org/wiki/Electrical/LightBulbAlternatives-BrighterBulbs
