Background:
About a week ago, after loosening the distributor clamp in order to set the ignition timing, the distributor drifted upwards. As I was tinkering around trying to figure out why my Pertronix unit wasn't working, I noticed that the shaft to the rotor turned freely. I thought I was in big trouble. List member, NAJ, offered me hope and solice that I may only need to push the rotor shaft down whilst pushing the distributor down firmly against the clamp to fix the problem. I breathed a deep sigh of relief as it seemed to go back down fine. However, I still couldn't get the car to start. I have spark (checks out with my timing light), and the engine will sputter and try to start, but conks out after a couple of seconds. I suspected that the timing was way off.
Now for the interesting part:
I called Pertronix to verify that they sold me the correct unit. They said that it was, in fact, the unit for my car. They said that most complaints that they receive turn out to be low voltage issues.
The technician advised me to do a static timing in order to attempt to get the car running. He advised me to take the following steps:
1. Set the engine to TDC
2. Remove the distributor cap and look for a notch in the distributor housing. He told me that Bosch puts a notch to indicate where #1 cylinder should fire.
3. Set the center of the rotor to align with the notch.
Here's the problem:
After following steps 1 and 2 above, I saw that my rotor was facing 180 degrees away from the notch in the distributor housing. I was excited to think that this might be the answer to the difficulties I have been having. I loosened the distributor clamp and eased the distributor upwards until the rotor turned freely. I pointed the rotor to the notch and worked the distributor back down. I could hardly wait to jump in and start the car. I was ready to start celebrating. However, it cranked and cranked, but not even a sputter.
Here's the weird part:
So, I went back to square one. Set the engine to TDC, and popped the distributor cap. --->The rotor was, again, at 180 degrees away from the notch for #1 cylinder! How can it be and what should I do? I am totally stumped and open for comments, advise, and ridicule. :?:
Don
71 280sl bosch dist. 116-062
