Author Topic: AC blower fan switch  (Read 3573 times)
sarasotasl
  • USA, FL, Sarasota
« on: April 25, 2010, 16:29:32 »
My blower fan stays on low all the time.  The Hi - Med - Low works OK but will not turn off when it's in the off position.
Can this be repaired, or do I need to replace the blower switch?
w113dude
Re: AC blower fan switch
« Reply #1 on: April 26, 2010, 12:05:19 »
If the switch has not been used a lot this happens, Take out the switch out of dash and spray it with good quality electric contact cleaner & rotate the switch back and forth, This works for me every time. while it's out you can check to see if it works right by using a ohmmeter.
sarasotasl
  • USA, FL, Sarasota
« Reply #2 on: April 26, 2010, 23:56:06 »
Thanks for the reply.  Will give this a try.
