I am planning to instal my engine back into the car after a rebuild. I topped up with engine oil to check for initial leaks.. (luckily). I used a new mbz gasket between the pan and the alloy sump casting.. after filling oil slowly seeped across the gasket and dripped. I removed the pan and then used Hylomar (blue) sealant instead of the gasket and again it seeps oil. Im about to take the pan off for another attempt... maybe with gasket and sealant this time, but Im thinking there may be more to this. The alloy mating faces look fine.. could the pan have a problem that is not obvious.? Has anyone else experienced similar..?
Paul
