Author Topic: part numbers for vacuum hose clips  (Read 2382 times)
Ron
  • USA, CA, Arroyo Grande
« on: May 02, 2010, 17:39:29 »
Hi All, in some car shots, I've noticed two clips on the vacuum hose that runs from the brake booster to the intake.  One clip is on the "holder" that has spark plug wires' clips, plus the left side of the throttle linkage that crosses the engine, and this holder is mounted on the left side of the engine.  The other clip is a double clip and holds the brake booster vacuum hose and radiator fill tank hose together.  Does anyone know the M-B part numbers for these two?  I cannot find them in the book, nor can my dealer.  Thanks Ron
1966 230SL, euro
Re: part numbers for vacuum hose clips
« Reply #1 on: May 02, 2010, 19:08:36 »
The double clamp is described here: http://www.sl113.org/forums/index.php?topic=8580
I believe that the member of the german group is in the process of reproducing them.
Let me know if the other one is the one in the photo, I may have one.
